Hi folks! Newbie here and I just acquired a Simpson ALH4240 with a GX390 motor and Cat Pump. I would like to remove the injector assembly completely and I managed to find a SS adaptor (M20 threaded connection) to completely replace the injector.
Question : is it ok to remove the Check valve as well from a safety and pump performance stand point?
Check valve and seat is 438 and 439 443 444 446in the diagram attached.
