Installed the new injector today from Southside equipment. Went form the 44-1 ratio to a 10-1 ratio.
Put the snotmenade in the mix and re tried the house that I failed on… The dirt was bleeding down the vinyl… I dropped to my knees and shouted to the pressure washing God’s “hallelujah!!” I cried tears of joy then proceeded with my day.
Always keep a spare ready to go. Once you use it it a few times you’ll recognize if it stops pulling well. Just be sure to flush it on your final rinse and should last awhile.
Thanks racer I’m going to order a spare now acctually. Never really thought about that, even if it only takes three days to get here that’s three days of cancelled jobs if it does go.
I called up Russ from southside equipment and gave him my pressure washer information and he sent me one! I think its called a high draw injector 2-3 gpm
