Im new to pressure washing....I pressure washed someone driveway the other day
hey i pressured washed someone driveway the other day and while i was rinsing the driveway, the water got in my neighbor yard. Is there a way to avoid it?
It’s water, what difference does it make. Blow the water the other way as much as possible.
:point_up: wisdom!
Oohh I gotta ask…how did you ‘pressure wash a driveway’?
Depends on which way your surface cleaner is rotating. Do you recall if your swivel spins left to right, or right to left?
Which way do they spin in Australia? Is it like the toilet flushing backwards?!
Close your doors bud, you won’t make it in business. A big part of this game is common sense and problem solving. I’m so sorry.
if water starts going into the neighbor’s yard, ill usually either leave them a bill for watering services in their mailbox, or if they complain while im there, ill apologize and run out quick to home depot and ill get a bag of quick setting cement and create a retaining wall :brick: in the most sensible area of their driveway. Sometimes if the water is really bad ill go with hydraulic cement as that even works under water.
If water starts going into the neighbor’s yard when im awake, ill either A)not really care, or b)if its flooding and making a muddy mess, try to be more judicious with my use of water in that area.
