Igx800 not pulling fuel
Recently bought a igx800 off of one of my buddies. Only has 18 hours on it but has been sitting for a minute. Was running a little rough and I ended up replacing the high pressure fuel pump and the low pressure fuel pump while I was at it. Now when I try to start it, I hear the fuel pump Kick on but it’s not pulling fuel into the line (or in the site glass of the in-line filter). Not an expert on motors but any ideas on more then likely why it wouldn’t be priming or pulling fuel?
If you remove the fitting closest to the engine and get fuel to that point (either by gravity feeding it or whatever means) then reconnect it should fire up
