Picked up a HydroTek SS34005V back in the fall to work on the farm. Came with a basket of parts and looked like the guy was replacing some parts, but stopped half-way through.
I took the drive belt off the pump and got the engine running - sounds like a beast! Now I am just trying to reassemble the pressure and heat side of the machine - and was hoping someone could post a pic to get me close enough to figure it all out. I’ve dug through this forum and all over the web, but there just isn’t anything that gives me the pic I need. Maybe a pic of the back of the machine, and as the lines come out of the pump.
Thanks, J
So i have found something that may be helpful to the whole community. Here is a detailed parts breakdown page for older Hydrotek units. Hope this helps everyone!
Enjoy!
I have no idea how to do that but try and look at some YouTube videos they might helpful, Goodluck👍…
Why was unloader, burner thermostat, flow switch & output nipple removed ? could of blown the coil ? I would call Russ Johnston @ southside equipment 888-243-6506 he will tell you exactly what to do. After you replace the unloader I would test the coil before plumbing the thermostat probe & flow switch by connecting unloader output to coil inlet & another hose to output to trigger gun to see if coil can take pressure looks like a great unit good luck with everything
