I have an older hydro tek surface cleaner and today the spray bar got a hole in it I think it had apiece of trash in it so one side of the spray bar was being pushed up and it wore a hole in it does anyone know if hydro tek sell replacement spray bars thanks
Sent from my SPH-L710 using Pressure Washing Resource mobile app
Yes. If any of the PWRA vendors sell hydrotek equipment they can most likely get you the bars you need. You can also call Hydrotek direct and they can give you info on what dealers you can call to get that part. Off hand I think Russ Johnson Southside Equipment Homepage is one of the PWRA Vendors who sells Hydroteks
Thanks John Im gonna call russ
