hello every one I know its a long shot but I just bought a hydromax steam cleaner with the coil taken out of it cause there was a pin hole in it. the guy has every thing hooked up to run it without the steamer and I just got the new coil and I have no clue on where to start. is there a diagram any one has or any way any one could email me a few pictures on how yours is hooked up. I appreciate your time thank you
It might help if you post pictures of your machine first so we know what machine you’re dealing with. The coil on my Hydromax runs horizontal along the top.
It looks to be somewhat similar to mine. My tanks are on the other side and the engine is facing the tailgate of the truck on the left hand side. I would assume they’re basically put together the same. Do you have the burner and everything?
Yes I have burner and every thing I need I’m pretty sure. I just don’t know how to hook the coil to water and then to the pump and what not
Call the guys at BCE and speak to them. Everyone says they’re awesome to deal with.
706-629-1768
Just run a 1/2" whip from the outlet on the unloader to the burner. Then run from the burner to your hose reel.
