Not PW related, but may be useful to someone.
So, I use my weedwacker for about 2 hours straight everytime I use it. In winter I completely drain the unit, start it till it won’t run anymore, then put it away until spring.
This spring I have used it twice, the third time it wouldn’t run for more than 5 seconds, wasn’t pulling fuel. I went and read online that the ethanol in our gas is killing these carbs (for what that is worth). A new unit is about 175 with tax after getting a discount.
SO I bought a replacemnt carb from the big A website. Came from China here is a link https://www.amazon.com/HIPA-545081848-C1Q-W40A-Carburetor-Husqvarna/dp/B01M8QF4C3/ref=sr_1_3?crid=2J1TGVEK7P81R&dchild=1&keywords=husqvarna+128ld+carburetor&qid=1591295909&sprefix=husqvarna%2Caps%2C150&sr=8-3
I installed it and it works just like new. The unit was $15 shipped. Just in case your wondering, like I would, when I removed the carb from the husqvarna it had “CHINA” stamped on it.
Here is the kicker, those fuel lines were a PITA to fish through. I didn’t own bent nose needle nose pliers, so I had to cut those fuel lines a long way at a 45 degree angle, then bend some wire hanger to fish them up enough to get to my needle nose pliers so I could pull it through. Don’t use the spark plug that comes with the new unit.
Just an FYI for people who DYI. I was highly skeptical that it would work, but was pleasantly surprised that it did. If it only last the rest of the year I am ok with that. On a side note, it doesn’t come with an air filter.
