Hi Guys, I am not very technical, always brought an expert to fix stuff until now I got in to this game.
I bought two 4,800 psi 300 bar petrol machines just before we got locked down, had to import from the UK as I cant get decent power / flow rate locally.
The first machine was leaking water when I set it up, it was coming from the bottom of the pump, I stopped and contacted the company and told them it had an issue with the pump,
set up the other and used that for the past month or so without problem.
meanwhile the company were in lockdown so communication was not easy and I though I have informed them so no problem I will get it replaced or refunded later.
Yesterday I had a different problem with the machine that was working, so today I thought ok lets take the good pump of this one and put it on the one with bad pump so I have a decent machine for a big job on Tuesday. I took the pump of the one and found this
Everything was smashed to bits.
I thought well at least I know there definitely was a pump problem !
I preceded to put the working pump on the new machine, all went well fitted fine no problem, even changed oil all good.
Started up the machine , started first time,
After a minute or so, Oh no water coming from bottom of pump.
Stopped machine took it apart and guess what
another pump mashed !
Both times I did nothing, that I know would have caused this, the pump damaged today was working fine yesterday, all I did was move it to an identical make and model.
the only common denominator is the crankshaft. any ideas what has happened ??
I really have no idea and want to at least sound “not stupid” tomorrow when I contact the sellers.
Sorry if I have not explained very well, help much appreciated !
