Just received my pallet of goodies. Super excited. Been moving things around since this morning and want to make sure I didn’t miss anything. Going to review Racers video again too. All the plumbing and hoses will be installed once everything is where it be. The black box will be the roof pump. Also going to raise the single hose reel. Any suggestions would be much appreciated. Measure a hundred times drill once.
I wouldnt use an elbow coming out of the water tank.
I would use an 45dgree curved elbow that way you could ad a dump valve
Get an unloader block too
That would definitely work better. Still early here on the west coast. Going to run to HD
Someone suggested a wash hose running from the top. Seeing racers video. I like his way.
There is no pressure there…even with the machine running
I won’t do that. Makes no sense to run a hose from the top. First trailer build. Just want to make sure everything is right.
I ran 2 machines, thus my pipping set up.
I suggest that when you turn off your machine, you closer the ball valve…then dump the water.
This way you trap water from the valve tut o your machine.
This way next job when you fill your tank you open the valve going to your machine and have no cavitation.
I find it get harder and harder to understand posts when guys such as yourself speak in tongue. You wouldn’t use an elbow because you would use an elbow. Ok, I got it.
Lol…not a 90 degree elbow but a 45 degree elbow.
Look at the picture.
Not trying to be rude here but I don’t believe you know what a 45 degree PVC elbow is. I do not see one pictured. Please by all means point it out for me as I may just be missing it.
In that picture you have a 90 degree street elbow into a DWV sanitary tee???
I guess you are right, that’s why I post pictures, did not know the technical term
No worries, just spend your free days on one of the PVC fitting supply sites
Here’s one for you with easy navigation.
https://www.supplyhouse.com/PVC-Schedule-80-Fittings-18700000
Take back gate off and put reels in back. Put another axle under it.
