• Yes, remove any loose debris.
• No need to rinse before applying pretreat. You can saturate the nearby grass if it makes you feel better.
• You’ve been here 55 days and don’t know the difference in SH and bleach so I’ll just leave that one alone.
• Again, nearly two months on this forum talking about washing something and you still don’t know dilution ratios for flatwork.
• No one here other than the Canuckians know how big 50cm actually is. Convert that to Freedom Units and then we’ll know.
• Yes, always rinse after surface cleaning. Large areas should be split into sections and rinsed as you move along.
• Post treatment helps with lines left from the surface cleaner. I do it every time. That decision is yours to make.
Thanks for the help!
Well, not sure about the hypo things, from what I know bleach is hypo in different % depending on the type of bleach, but I could have also any additive for example for smell which might be bad for powerwashing or something I don’t know. Also I don’t know what % would be great to use in this surface of hypo, something like 3%??
50 cm are 19.85 inch
For post treatment should I use also bleach?? On other thread someone mentioned oxalic acid or something like that.
@PW.SP did you really take a job and have zero idea what you are doing. Please tell me you were at least honest with the customer. Why dont watch @Racer video
1 blow off concrete
2 pre wet concrete
3 apply pre treatment
4 allow to dwell to dont let it dry
5 surface clean in small sections rinse before dirt settles.
6 allow to dry post treat
