Hello! I am new to pressure washing and am worried about removing oxidation from siding by using too much pressure. Would it be a good idea to apply my SH mix and then rinse with a garden hose or take the hose out of my SH mix and rinse with my soap tips? Would appreciate any advice!
Rinse with soap tips. You could also get a larger orifice on your rinse tip. Like double the size youre using now. That way you wont have to fiddle with your ds injector
I have a 4pm machine so get maybe a 8gpm soap tip?
Bingo
No, use normal soap tips for your machine.
Thank you all for the advice!
I’d get a 4 gpm jrod from Pressuretek if I were in your cowboy boots. Drop the tube into a bucket of water while rinsing, that way it won’t be sucking air and more importantly you’ll be rinsing out the injector which will make it last longer.
