How to get dark gray streaks off of gutters?
Just wondering the most effective way to remove the stubborn dark gray streaks from gutters?
Brush them with gutter butter or f 13. Be careful with f 13, it will turn concrete orange.
Based on some things that I have seen posted…EBC works well for tiger stripes. I don’t know if this is true, but I am gonna find out. And, you don’t have to be so careful with it.
I have been using a product called gutter zap with good results brush it on and then rinse
Like brush it on with a paint brush? You can’t spray it on with a pump up sprayer?
No I use a soft bristle brush on a extension pole or a painters pole and do about 15 to 20 foot section at a time because you don’t want it to dry then rinse with your water hose
Gutter Butter the best thing for gutters I’ve ever used.
Watch the concentration with f13. Start with a weak mix first. It can remove color from the gutters.
