I have a 3 month old new concrete driveway I want to seal before winter start , how can a clean the tires marks before I do the clear seal ?
Soapy water and a stiff bristled brush on a broom stick.
Front 9 Double Eagle process.
On 3 month old concrete?
Will tried I have a power washer and lemonator I’m going to tried some lemonator with power washer very small tip in it , and a broom to see if the tires marks comes out !
Wait, what?
Very carefully with your surface cleaner set at about 1800 psi - use a degreaser, something like EBC, with your pre-treat.
Can I use simple green , for tires marks , I have a 3200 psi , what tip will give me around 1800 psi , sorry I’m a rookie and don’t want to mess up my new driveway ?
I’d go with soap and brush as suggested, maybe a bit of degreaser. On concrete that new I’d be careful with any pressure and test an inconspicuous area…and avoid anything with the word “sodium” anywhere on the label!
Yes, this is probably the best way to go, especially since good advice seems to be repellent to you.
Thanks for all the subjections - advises will let you guys now
Just the tip lol
