The job: Three limestone offices that all have polished concrete window ledges.
Challenge: Obviously I don’t want to apply any pressure but not sure what solvent to use. SH is not removing the black streaks.
Thank you for the guidance.
Any pics?
What % was applied?
Started at 3% and went to 8%.
I’ve only ever had luck using medium pressure, but the other guys should comment.
Hot mix, medium pressure after. If that didn’t work then the polish could be acting as a barrier.
Tried medium pressure. Nothing. Got a little close at first and left waves in the surface. I’m stumped.
I’ve got a few office buildings I clean that have that. It often takes several applications and letting it dwell awhile, like 10min between each one. Much more than 7-800psi doesn’t seem to make a lot of difference. Multiple applications seem to work the best. A lot of times I’ll use a pump up with straight SH in it and that works too. Still need to let it dwell.
Straight SH in pump sprayer, repeat and rinse. High SH like @Racer said has been the only way it’s worked for me. Just takes time……
