How do you reach 50ft height ? Nozzle vs telescopic?
Now i am dead scared of popping the wrap around my new telescopic wand!
Poping the wrap? Opening? It’s a good tool to have! When you need it you need it!
Agreed. I’m going to keep mine even if I never use it… might need it for SOMETHING at some point.
I use mine once a year for about 2 mins max. Haven’t used it yet this year thankfully.
I rarely use my extension pole. But when I do it’s usually just to get to some awkward angles up high. If the wind is bad, I’ll break out the old x jet and extension wand just to get hw at a peak or chimney. I don’t like it, but it solves a problem. I use mine about 10 minutes every two weeks. Also good for getting rid of those stubborn dirt dobbers nest. If you use a larger orfice sized tip the recoil isn’t nearly as bad.
Schertz, I am guessing you use one of those double headed gutter cleaning adapters? Does the combo work fairly well for that? Do you use it on both dry and wet leaves? Does it make a mess? Thanks!
Yep! Points both ways. Use it on wet or dry leaves, sticks and small logs lol. It makes a mess and that’s why I sell it with a housewash if at all possible!
Thanks brother. Great information!
I also use the gutter cleaning attachment that has two turbo nozzles on it that point opposite directions with a 24 foot extension like shertz. It works great! If the gutters are full it does create a mess. But if you have a pressure trapped unloader hitting the trigger every few seconds blasts everything out of the gutter and cleans it as well. I’ve tried cleaning out by hand and it just takes longer…plus with this I’m not on a ladder. I know many would argue this concept but as long as you have your pressure washer to rinse it’s all good…plus sell it with a house wash like mentioned.
Do you guys use that GutterBall attachment or this? https://www.amazon.com/Powerfit-PF31052B-Gutter-Cleaner-Attachment/dp/B008BOVQQ4/ref=sr_1_6?ie=UTF8&qid=1527624677&sr=8-6&keywords=gutter+nozzle ?
Those things make a mess of the roof line, blow the end caps off gutters and don’t clean the downspouts.
I have it, it works.
i use the hook attachment for downspouts it works great. not so much for the actual gutters though lol.
