Hi
I know Karcher has the dirtblaster (comes as standard with the K2), but I am looking for a more powerful option, if it exists.
Thanks a lot
I now know that pressure washers can be fitted with various degree nozzles, like the ones in Choosing the Right Nozzle, but I do not know yet if they can fit in the washer I have, which has the quick connect feature.
Every time he says Luke Bryan CD mentally replace it with Karcher K2. Then when he says listen to Skynyrd insert 4 gpm or higher gas driven machine.
OK, I know the K2 is weak. I might think of buying a better one.
Thanks
I think the K2 cannot be fitted with the four colour coded nozzles, nor the turbo or any others, coz the accessories in its page do not show the nozzles.
The K2 only puts out 1.25 GPM. That isn’t a pressure washer. That is a moderately wet fart.
OK, I will think of buying the better ones.
Thanks
I’m dying here. ![]()
