Which M5 are you using? For distance you need the 7-12. If you want a little more pressure,go down one, but you’ll get a little less distance and more mist at full open, but great for doing steps or anywhere you need a little more pressure.
I don’t think I’m getting anywhere near 1800 psi with mine at end of hose, probably few hundred. Will try to remember to check it tomorrow.
I think I have it figured out, maybe. AFTER opening my throttle all the way on my Kohler 26.5 with General TFSF 2021 pump, spraying horizontally across a parking lot with the M5 rated for 8gpm getting about 35’ @ 300 psi
With the Assassin Nozzle rated a 4 gpm getting about 45’@ 1800 psi but its a misty pattern. Thoughts and suggestions please.
