Can the valve be removed so it hangs down under the box? I like it already.
I did some testing yesterday. I was getting 23 to 1 removed about I think 8 foot of tubing from both tubes now I’m at 20 to 1.
I’m not sure what you mean when you say “can the valve be removed to hang below”. If you’re asking about orientation you can mount it any way you want. @Harold can probably give you more info on it than I can.
Squid has his mounted outside the box.
What I mean is, can the valve body be separated from the control box upper so the valve just hangs outside the box?
Mine is fully inside, tried to separate it but the plastic box walls are too thick for that.
Can it be done or can it be done easily?
