I bought a used belt drive 4/4 last fall to ‘flip’ this spring. I got everything straightened out and did a pump oil change (TS1511) then ran it a few times. Good pressure and GPM verified with my gauge.
I’m probably answering my own question but thought I’d check for sure with you all, the oil is a light honey color, even after changing it twice and letting sit overnight. Using 30wt non-detergent.
Are the seals shot and mixing with water or just getting aerated?
I’m getting qthe same issue with my tsf2221. i think it’s air as the amount of oil didn’t seem to increase, that i know of. I’m also using the non detergent 30w from the mart.
I wish more folks had similar values. I bought a boat once & the seller had jammed a piece of wire in the throttle control to make it ‘functional’. Luckily it fell out in the driveway. It could have created a life threatening situation if it happened on the water at full speed. All so they could screw somebody out of a few bucks,
