Honda GX690 Starting Issue
I just watched this video, looks like there is a fuse behind the starter switch. Bit of a bear to get to.
If no hours showing, pull the fuse……
Yes the fuse is blown, i tested it and no current goes through. Hopefully tomorrow morning as soon as store opens i can just throw a new one in and it starts purring again!
Thanks a lot for the help, immensely appreciated.
And i learned a lot working on it!
Note to self: gasoline tastes bad, get little hand pump instead of siphoning next time i check fuel line.
Now i’m wondering what caused the fuse to go out in the first place…
You should have a little pigtail with that fuse in it hanging out front for easy access. common problem. BCE puts it on all of theirs. If going to parts store pick you up little fuse holder that has both wires and extend the connectors behind switch so that you can get it around front.
Yes it was the fuse! Now let’s roll!!
