Here is little project I’ve been working on. I am just starting out and wanted something small.
That’ll work till you save for more. Two things
- Will you just coil up the hose after each job? If so, maybe put a cam lock on the pressure side of your pump so you can easily take it on and off
- Are you using this to post treat concrete, wash wood or a whole house? Do you then plan on using a pressure washer to rinse the house or deck or whatever?
Yes that’s exactly what I was gong to do with hose. Also yes I have a 4gpm, surface cleaner and a remote down stream injector with a jrod and a m5 twist. This is just used for roofs and pre-treating and post treating flat work until I get a better setup on the 12v side I will be building a proportioner once the time comes.
Is that a 7 or 5.5 gpm 12v pump? Love the build btw. Very minimalistic.
Thanks and that’s a 5.5 will get a 7 once I get more into this just needed something to start with on the 12v side as I have the downstream for everything else.
Sorry man but you’ll hate trying to push that style cart around. You want the wheels to be toward the handle.
Thanks man ya hopefully I won’t have to do it long until I have a nice setup.
