What kind of DS injector are you guys using in order to apply soaps at higher psi? I am starting out with using a 3 way valve to change my 2 step soaps but there is no way my current injector will pull at anything higher than 500psi.
I believe upstreaming or using one of them fancy 2 step guns is your only option. @Hotshot?
2 step guns are using a downstream injector at high pressures so I figured those have to be able to be purchased somewhere. I found a guy thats makes and sells 2 step guns and is selling me an injector.
Call Russ Johnson at southside equipment in Kentucky, He’ll have exactly what you need, he’ll sell you all the parts to make it yourself if thats what you wanna do. The ds injector is gonna be 1/4 " , not 3/8 like the ds injectors that y’all run.
Hi Hotshot, Where can i buy a two step gun other than the hydrochem two step gun. My hot pressure washer specs are 3.5 gpm 4000 psi.
Regards
Paul
Hey thanks!
I know Miguel personally. Great guy and is passionate about fleet washing. Ive spent the day with him using his 2 step gun when i was looking into starting fleet washing. Its a solid piece of equipment.
Does he have a phone number I can reach him at? I am trying to get one asap. And do you think it will work on a 4000 psi 3.5 gpm machine?
I just told him to join the forum. You can find him on facebook and message him.
