I’m in the process of having a van wraped and thought about using some before and after shots but the ones I have from my Iphone will not blow up enough without distorting.
Does anyone know if there Is somewhere I can get my hands on some.
Wont be doing any more washing before the wrap goes on in about 2 weeks.
Any digital camera with at least 10 mp would do fine. In fact if you set your iphone settings to hr. The designer should be able to use it. Actually the designer should be using vehicle outline software to design your vans layout. As far as he needs to design a phone image is sufficient.
Should have the basic design tomorrow but the photos I have will not blow up as they are all 2 mp maximum I can go back to re shoot the afters but will need before and after for it to work properly.
The other option is to not have photos .
Are before and afters necessary?
If you have to make it larger it will not look good on the vehicle… there are websites dedicated to high res photos just for vehicle wraps. Yes, they cost money but its worth it.
Here is my van… I actually had to shrink the photo of the mower to fit the van.
