Hey guys, one of my pressure washers shot out on me today. I don’t have another job for two days, but I like to have two pressure washers for when something goes wrong with one or the other. Do you think I can get rid of the one that’s shot, get a new one tomorrow, trying to get a 5.5gpm. And take my 125 gallon tank and turn it into a buffer tank? And of course have to get a bleach tank then too. I dunno if this is too much to get done in one day.
I’m not really sure what you’re asking but sure, you can turn that tank into a buffer. Once you add an SH tank you’ll have to be careful traveling with too much water in the buffer tank.
You can add a SH tank later. Just carry the SH pails and fill a bucket with your mix. Is the picture your setup? If you can get a machine in one day just swap them out.
Yea that’s my set up, I’m just wondering if upgrading to the 5.5 is worth it or not
The buffer tank alone is worth it. If I had to choose between a buffer tank or SH tank I would choose a buffer any day. Like Bill said, you can always carry jugs of SH and just use a fiver for your mix. It’s so much easier not having to worry about being on the gun all the time so the pump doesn’t overheat. I don’t think I could wash without a buffer. You’ll definitely notice a difference going from 4 gpm to 5.5 so I would upgrade if you can.
Yea having to be on the trigger all the time is getting old, I’ll post the new setup tomorrow if I can make it happen
I was tired after a long day at work, then i saw the picture of the tangled hose on the reel and now i’m even more tired.
I just ran the unloader on the ground
Yes to all of those. Also your hose reels make my brain feel crazy.
I can’t keep the thing wound up for the life of me, where the hoses connect makes it all crazy
Any suggestions on how to clean out my old chem tank to turn it into a buffer?
Dilution is the Solution to Pollution.
Lol, I see what you did there.
