I WOULD LIKE TO KNOW HOW CAN I MIX PINK THUNDER TRUCK WASH, SOME TIMES I USE THE X-JET, DOWNSTREAM AND SNOW FOAM LANCE… HOW MANNY ONCES OF PINK THUNDER SHOULD I USE…???
THANK YOU
THANK YOU
To each their own but I would never downstream, snow foam or x-jet any equipment. The ratios are listed on the product page so there’s no need for me to copy and paste them here. I mix my particular soap at around 35lbs per 55 gallon and then upstream it sometimes on a rare occasion I’ll double upstream it for twice the soap.
