Hi guys,
I use a 17LPM (4.5 G) 3000psi Honda GX390 with Xjet M5
I have already ran into a massive problem cleaning a patch of my brothers house (for some before and after pictures). After I did my wash the concrete turned orange!
My process was:
Sweep up
Rinse concrete
Spray with chemicals
Surface clean with surface cleaner
Tidy up edges with wand and final rinse
My chemical mixture with xjet
SH 12.5
Surfactant 150ml (5oz)
Water-SH 1:1
10L Water (2.65gallons)
10L SH. (2.65galllons)
=6.25% SH
Open (no tip attachment for xjet)
=3.67% SH
I will put images of before and after to display what results were.
I am so confused on what I did wrong to make the orange happen.
Please if anyone can help I can’t start the business until I get this sorted.
I used the green (25050) nozzle.
I had psi at mid strength as well while using wand ( any be sure on exact psi estimate 1500)
And the surface cleaner was a BAR 20" BE Whirl-A-Way Surface Cleaner.
I’ll put picture of wand and surface cleaner
Sorry I left that out.
2 x 020 - 25 Degree Nozzles on a single bar.
It’s a 4000psi 21LPM (5.5G) surface cleaner but machine is only 3000psi 17LPM (4.5G)
My original thought was that the concrete was that colour underneath and I stripped it too. But I’m hoping not.
I am going there again in morning I’ll put another after picture up.
My original thought was iron in the water may have caused it, but if you used treated water could be something else. I would take an acid suck as oxalic or muriatic, start lower strength and do a test spot to see if it takes care of it
So I’ve returned taken some more photos.
It has faded a lot and the small spot is completely cleared up.
I am gonna return once the sun has been over it and see how it is.
I am still completely confused on this and haven’t seen anything like it throughout all my research.
Interesting, I always use lower pressure on newer concrete… looks like you may have taken some cream off the top and the concrete has a slight orange color underneath especially when wet. Try treating it with oxalic to whiten it up some it might help.
Those curved impressions don’t look like an SC to me. They stop at the joint and don’t carry onto the next edge section. I’d wager they’re tool marks from spreading the concrete. That would make removing the cream an unlikely issue. May have been something in the concrete mix
