If I decide to go with an 8gpm I’d like a Honda 690 with an Udor geardrive pump,
I think @SchertzServicesLLC has built one with a predator but I could be wrong.
Ive been trying to search for it but can’t get the search to work on my phone.
I think the water Dragon setup is what im looking for but without a $3600. Price tag…
What pump do you use? And can you actually come out cheaper if you do it yourself?
I found a BE 8gpm for $3000. It just sounds like alot when I only paid $1300. For my 5gpm
Hopefully I can get my search to start working again that way I can do my own research
I had about 2k in my build after all the sip lines, unloader, block, udor pump and predator motor. Runs like a charm.
I built one for around $2,900. Udor gkc 30/24 gear drive, Udor heat treated engine key (heard about the gear drives sheering keys so I called Udor and they make a special key you can buy. It was like $12 part number 6914.83) Honda gx690, Honda muffler, battery, 3/4 mpt x 1" Barb inlet fitting, unloader and unloader block, aluminum skid (couldn’t find a steel one online), fuel tank.
Those Udor guys are awesome, Randy has always taken care of me
