I just pulled up for a night of truck washing with two guys on the clock and one of my machines sounds like it’s turbo charged. Rpms are really high I think. It was misfiring last week so this morning I changed the oil and put new spark plugs in. Tested it and it ran fine. Problem just started when I got out to the job site.
So far I tried putting the old spark plugs back in but that did nothing.
Any ideas of something I can do to fix it in the field?
I’m giving a diagnosis based on written words. I may be wrong, but probably not. If it’s the governor you probably aren’t going to get a days work out of it.
The shop I took it to said the governor is completely shot and recommend that I get a new engine. They don’t offer a rebuild. Engine has 1500 hours on it. Does that sound right or should I take it to a different shop?
I write all my oil changes and major repairs on my machines with a sharpie. I know that I replaced the governor on one with about 1500 hours and it has about 2300 now. Find a better mechanic or do it your self. If I did it in 5 hours, a technician should do it in three. $270 labor plus parts
I second finding a new technician or do it yourself. With that said the governor controls your throttle position to keep your engine within the recommended rpm range. You could always buy yourself a Hardline tach/hr meter and set your throttle manually to the recommended rpm range and call it a day.
Going to try and call every shop in an hour radius tomorrow and see if they can do an emergency service. Pretty upset that my machine sat in the shop for two days only for them to tell me they can’t fix it. I figured it was taking so long because they were working on it.
