In this picture am I right that this is the screw to drain the carb? I did run it dry when winterzing but tried to drain it a nothing came out, guess nothing there to drain?
Also, in your buffer tanks, do you get the water out that remains even after using the drain valve? Like the amount that is a bit lower than the opening. Thanks
