Going to get a new pump. Currently, have GP TS1511 4GPM 3500 PSI.
Thinking about switching to Udor & also increasing the GPM to 5.
Want to avoid changing the pulleys if possible.
Wanted to see if anybody had recommendations?
@squidskc What is the pump you told me about one time, the udor?
I just bought that same setup, what does your belt alignment look like?
All you need to do is find a 5gpm pump that’s rated for the same RPM (1450, if my brief search was correct). It’s a pretty standard speed for belt-driven pumps, so shouldn’t be difficult to find.
Udor has a very good reputation in the industry.
