Why would i want the the honda gx630 over the gx390 for 5.5gpm? I’m seeing most or all have setups have the gx390 at 3000psi and the gx 630 with 3500 psi but If found a 5.0 setup with the same 3500 psi for both then why the bigger engine? I know most people say all you need is 3500 psi but i might like the 4000psi. I do see on the powerwashing store they do have more combos where you can get a gx630 with 4.5,5,0, 5.5 gpm with 4000psi and cat, GP or AR pumps.
You can always upgrade to a bigger pump in the future with the 630 vs the 390. Maxed out already on the 390……
Just light it up and get it done, bleach blaster.
You won’t get 3000psi and 5.5 with a 390, maybe 2500.
I (foolishly) bought a 5.5/3500 630 when I could have bought the 8gpm/3500 690 for $500 more. It all worked out though, Russ hooked me up with a gearbox and a 8gpm pump. I’ve never needed more than 3000psi anyway.
Texan you’re jealous of my username dude you can be bleach blaster 2.0 its ok ill give it to you. so the reason i would do 5.5gpm is because I’m not carrying a lot of water
You don’t need to carry water. I run a 8gpm and my buffer tank is only 55gal.
stone is fine Texan . stick to what you do best, protecting the border.
dcbrock yeah maybe but doing something of longer continuous use like a surface cleaner could catch up to you . i wonder what the math is for that 55 gallon on the trigger no letting off . id have to figure it out
Oh, really? Want to take a picture of it tomorrow and post it here? If it’s all good I’ll gladly admit that I was wrong and leave you be.
when i get a chance
Okay, I’ll hold my breath.
you really must not have a life to be tailing me like a love sick puppy
Nope, you’re just the only person ignorant enough to give yourself the moniker you’ve chosen and then knowingly damage someone’s property and then blow it off because “the customer hasn’t said anything so…”
I. E. You stick out like a sore thumb.
you need a job texan
You need a set of morals, bleach blaster.
dude i have a thread about machines , move on
You’re from Houston, right?
Hey hey can I get in on this, I’m from DFW originally.
