I need one of these with about a 15-20 foot hose for gutter downspouts! Would be awesome!
You thinking from the top or the bottom?
Bottom. Stick it in and blow it up. I don’t use ladders unless it’s well paying and a must.
Just a suggestion. Check out Piranha hose at Georgia Rubber.
Got a link?
There appears to be a hose company called Piranha
Would that hose be able to go through 90 degree angles?
I carry a Rigid tool box with a Milwaukee driver to take apart gutters to clean if needed
Jay I don’t have a link and it may not be Georgia rubber anymore. I think its Atlanta Hydraulic or something like that. Piranha is the name of the hose. It has a hard slick finish so it has less friction than rubber but still flexible. If the pipe is PVC with a 3/8 hose it will go around a 90 in a 4" line. You may have to bump the pressure a couple times. If its clay tile it may or may not make a 90 because of more friction. I’ll work on a link for that.
I’ve heard the donkey thing called even worse lol.
