Using it with my 8 GPM I have 40045 nozzles. I haven’t tried it with the 5 GPM machine. I don’t use hot water so I can’t speak to that aspect.
So i have a 5.6 gpm hot water machine at 3500 psi so i would need two 3orfice nozzles right? Do you have a place i can order from
3.5’s is what I would get
OK need a Lil help… so I washed a driveway today and used my SC at 2500 psi moved slow and still ended up with lines and swirl marks…after reading about tip sizes I just want to make sure I’m right. I have a 4gpm 4000psi with a 18" hammerhead two nozzle SC normally I’m running 3000psi for concrete. If I read right, my nozzle size should be 2504 or 2502? iv seen both recommend so just trying make sure. Nozzles on there now are not marked so I don’t know exactly what is on there.
I have the same SC. I took the factory ones out & replaced with 2503. Haven’t had any problems. Also not sure what your process is but post treating with a 1-2% mix works good for me
Thanks I post about a 3%
Remember to buy 4 nozzles. On the job one of them will clog. Simply swap them both out on the spot and clean them at home.
The 25* is the spray pattern. It should have the orifice size listed somewhere.
I got that, my question is there two of each so there has to be something different it doesnt say anything in the description is the threads different or something. The pics I posted are all 4 different tips 25* just wondering
The bottom two are what i use on my surface cleaners. Fins protect the nozzle a little I guess
OK thank @Innocentbystander Them are two I was gonna order but I seem the others so I wasn’t sure.
I used 2 x 2503 nozzles for my 4GPM 3500 machine on a hammerhead 20", I get plenty of lift even at 1700ish PSI. 10/10 would recommend…
