I’ve got a leak coming from the bolt circled. It’s not bad, but before I take it off and replace whatever seal or crush ring is behind it, I wanted to check with you guys. Thank y’all.
I don’t have any general pumps, but if it’s has a crush washer you should be able to see if. Try tightening it. If that doesn’t fix it take it out, put some permatex thread sealant on it and you should be good. Socket is always preferable to a crescent wrench
That bolt is simply the other pressure outlet if you wanted to switch sides.
