I am still learning here but have researched a lot. I had a job yesterday where the top section of an aluminum garage door would not come clean. I have seen this a lot where the upper sections of siding and garage doors, typically these sections are covered by an overhang, have a caked on dirt that is really stubborn to remove. I did make decent progress but it still looked dirty when I was done.
In this home yesterday the garage was facing north-west and I was there in the early evening so the garage door was hot from the sun.
My attempts were:
rinse the aluminum garage door to cool it down
tried SH - .75% - since it’s not organic growth this did nothing
Tried LA Awesome - diluted then straight - showed promise but I needed to scrub a lot and I was getting close to bare aluminum.
Tried diluted Gutter Grenade - same results as LA Awesome
I have not tired Purple Power but wonder what the difference in PP and LA Awesome is.
Man we have a ton of that here in Louisville, atmospheric crud (fallout) just collects under eaves and doors. I’m not much help though as all I use is some type of degreaser which you already tried.
Aluminum brightner - will make it look new Pump spray a lite coat on it, let dwell few min and rinse with medium pressure fan spray. I use my m5ds so about 500 psi
