You have your sections on cam locks or just the factory swivels?
No kidding. Always pops right back to shape once you hook it up but I still like water in there just to help the ends from kinking.
My hoses like to sit in the garage when it’s in the high 90’s. No cam locks here. I just thread em on.
Intake is just as important and discharge. Never understood the y splitter
I’m with you, I bought one but never installed it.
I use splitters to feed multiple trucks from a fire hydrant
I used to have the Y splitter from Ace Hardware and it works good for changing the incoming water to an outlet so I could fill buckets. But now I have a hose connected at the bottom of my tank with a valve at the end that I used to fill buckets, but I can also plug it into my 12 V to rinse that with water after transferring bleach.
What is all this talk of buckets?..we’ve never had one leave the shop on a truck… ![]()
I picked up a beefy one last year at Tractor Supply, with a shutoff on each leg, still at least 1/2" bore in the ball valve.
