Hmmm. I’ve searched and found nothing on it so it’s probably not a good idea. Use a foamer to slow roof runoff? Incompatible with snotmenade, etc? Thanks!
I use a foamer for rooves and on most jobs
What do you use for a roof mix? Thanks!
I experimented with foaming roofs for quite a while. End results
Pros
Used less chem
Coats roof muck better
Looks awesome doing it neighbors gather looking
Cons
Takes to long to break down making grounds guy keep circling the house again and again.
Drives grounds guy nuts
Pissis off grounds guy
Makes grounds guy feel inadequate
Slows down overall job.
Also makes grounds guy mad if I forgot to mention that.
Yeah but how do the ground guys feel?!
My concern is just minimizing run off.
I also use hot water when i do rooves
It doesn’t minimize it . It just slows down the process
How and why do you do use hot water??
I am guessing tiles?
Do you have any videos of you using the foamer on a roof? I’d be interested to see it.
I’m assuming he is down streaming with a hot box. Not sure how else you could heat up a tank of Sh . Not to mention I’m pretty sure heat is one of the things the break down SH
I’ll see if I can dig one up it’s been several years.
I DS,
I use hot water cause it is faster.
I do not have videos of roof cleaning, i only do max 2 a year.
Cause i only do the ones i want, i dont get up on ladders…
I have few foaming pics on FB and i pw video
There’s a couple videos on YouTube. I searched for foamer and roof.
