Dirt and debris can collect inside your pressure washer when it is not in use. This debris can damage your equipment if it is not removed before you pressurize your system.
good info. thanks!
I was wanting 2 know what do I put in the water reservoir to flush out any rust or calcium buildup that may clog up the lines and possibly blow up my unit?
Bubbler. You don’t need to worry about build up. No one actually does what is in the video. If you have a hot box you can run a descaler thru it because that will generally lead to holes in the coil that shall pieces of rust was keeping plugged.
