Hey guys, I had a brick cleaning job yesterday and the customer said the bricks were white so I tried to use some fluorescence cleaner and it made it worse. Any suggestions on how to get this remedied?
Thank you
Thank you
Assuming the photo is after your treatment, what did it look like before?
What was your dilution ratio?
not everything that is white on masonry is efflorescence.
Go look at the encyclopedia of clean. They give you a couple of things it could be.
