I’m a fleet washer but got asked to clean up a floor at a water treatment facility by the city here. A lot of the grime is water spots that have stained the floor with the dirt that’s been collected.
There is some PVC pipe glue on the floor that they want cleaned up as well. Anyone ever clean that up? If so, what chemicals did you use to clean it?
The plan is to use a surface cleaner for most of the job and wand around the walls and fittings everywhere. Going to use two hot machines and two SC.
