Long story short I’ve been trying soooo many brands of fleet wash chems. 2 step, 1 step. Car wash soap, foam cannons. Zep, and it seems all of those chemicals do the same thing. Maybe it’s re labeled and says brushless. But haven’t found a true brushless yet. I clean fuel tanker trucks and they’re all mirror polished. I’m a one man band here so it’s VERY hard to get things pre treated,brushed, rinsed before things dry. It almost dries instantly.
Any of yall out there have something that actually works well enough to pull all the road film off?
After I’m done, once it’s dry. It doesn’t even look like I’ve cleaned it. Tires look like they’re still dirty. That’s me even using pump up with STRAIGHT degreaser and hot water. The cab of the trucks are white and only way they come clean is after they dry I have to use a quick detailer spray like meguiars and a microfiber to get it clean. Takes me about an hour per truck… and cost a bunch in chems and time. It’s getting old doing it like this but I’ve also tried venom and viper from fleet wash supply and it works pretty decent and I’ve tried different ratios but still haven’t gotten the results I’m looking for.
8gpm gx690 / pressure pro burner. 200’ hose - super sud sucker injector. 5 gal soap tank. M-5 twist for downstream application.
