Does anyone have a replacement 3 way valve for the bandit roof pump sold by Pressuretek. I broke the lever off by overturning it. I order a replacement from Pressuretek but the 3 way poly valve will eventually break again. I’m looking for something that will hold up longer.
Personally, I always go with Banjo valves…you should be able to fit one there with little or no hassle. I’ve found Amazon to be the best place to get them, with U.S. Plastics being runner-up.
(FWIW: U.S. Plastics price is cheaper, but they destroy you on shipping)
US plastics had a bad batch of stuff last year. They sent me 2 dozen ball valves free to replace a bunch that only lasted a day . You might be getting old stock.
I’d like to go with Banjo but I also want to try and keep the same mount and I don’t see a Banjo 3 way yet that will mount like the original Bandit 3 way valve. If I do I will post it.
You can make anything. Or, draw up what you want made and send it to me and when it slows down I’ll fab up something for you.
@Innocentbystander thank you. I’m going to try and make something that will last longer I’m just not sure how to make it look “pretty” if you know what I mean. In the mean time I’m going to put the same poly 3 way valve from Pressuretek back on till I can get time to make a long term fix.
Pretty don’t make money lol.
Sure I do
