What have you all found works the best for lubing the QC fittings? Silicone spray is decent but doesn’t last very long.
I use Rem oil. It works well. If there is something better, post it.
Pool and spa lube per Racer’s posts
They do not need to be lubed
I think is better to replace them.
I use this when i winterize the equipment
I have some of that, will try it next time.
Note: Regular wd40 is a cleaner, not a lubricant.
But I use magic lube, same stuff used for pool pump gaskets
Thing is i probably don’t lube em often enough, but will replace them if needed, or flip them over
