I was asked to clean this aluminum fishing boat this morning. The outside of the boat doesn’t look to dirty but they would like to clean the carpet as well… what do you guys think?
Go for it! If it pays well. Much success.
We two step them with awesome results.
What exactly do you mean by two step?
Two stepping is using a low ph soap application then immediately applying a high ph soap over top then rinse, then boat looks like new. We wash commercial trucks for a livin and only do boats for our every day customers , and SH would ruin that interior imo.
I have to learn to do this. Some kind of crusty thing is on the boats ruining the lake eco system about a county or two over. Telling people to PW their boats before putting in.
Would this work on pontoon boats? The big tube things are all aluminum. I don’t own a boat, so I have no idea what they are made of.
Man, crocs and a speedo all summer, that would be living.
I need to wash my aluminum boat which looks like the above boat. What is a good low pH soap and a good high pH soap??
What he said ^
You’re gonna be racking up the tips out there with that outfit
Ahh that would be a dream come true…Service with a smile, and if you tip well enough maybe some dancing LOL.https://www.youtube.com/watch?v=aDKEGNIEx28
Absolutely!! It will shine the aluminum, paint ,decals, trailer and bling bling your chrome trailer rims with the hoopdee spinners you got homie.
Hydrochem systems outa Michigan, I recommend dyna clean and quick silver. Then hit it with hydrosheen for a rainex shine that will bead up for over a month.
What is in the actual chemicals? what are they made up of? You need to do us a write up on how you do it, there’s no fricken way I’m reading that rubbers scrubbers thread.
Google hydrochem systems in Michigan Muscle.
They may also have an audible version for the slower crowd.
The simple most cost effective way is to install black soap tip and DS #1 soap then switch over you 3 way ball valve to #2 soap and apply over number #1 soap then all the dirt and oxidation chemically explode off the finish your trying to clean, Then switch to a 40° tip and start rinsing but we don’t rinse nearly as long as y’all do. Its kinda like yall washing houses but with 2 chems and zero dwell time.
We apply all our soaps with 1500 psi then rinse @2000 psi to speed up the process via 2 step gun system. but your talking $2500 for that set up so the cheapest way is just the ole tried and true DS method I mentioned above.
Congratulations @MuscleMyHustle you are now a rubber scrubber.
Thanks hotshot, great write up
. PDF worthy.
Dude, your spying on me, how did you know about my spinners?
Thanks for the information. I may never put it into practice but it is bookmarked for reference. Appreciate you taking the time to make me more informed.
Ant time sir dirt, I learn so much from y’all I like to give back when I can my friend.
