Who did you buy your pump from?
Jesse
Atlas Services
Exterior Cleaning Specialists
North Carolina
Jesse
Atlas Services
North Carolina
Mroberts do you run 5/8" hose 3/4" or 1"?
Jesse
Atlas Services
North Carolina
[MENTION=12088]Atlas1[/MENTION] believe it or not you can get those pumps on ebay… I use 3/4" hose but I sure do miss the 5/8"…3/4" hose gets heavy after pulling it around on the roof all day. 3/4" hose is the standard for all 1" AODD pumps.
Thanks for the info! If you had it to do over, would you just stick with a 1/2" pump? Or is the extra weight of the 3/4 hose worth it?
Jesse
Atlas Services
North Carolina
Also, is it poly braid hose that you’re using, or something else?
Jesse
Atlas Services
North Carolina
I still have my first 1/2" pump I use it to transfer chemicals into my mix tank. The 1" gives you the option on how much you want to crank up the spraying power, I wouldn’t go back… My spray hose is Kuritec from Pressure Washer Products.
I got mine on Ebay as well. These pumps can last forever especially considering they were built to work much harder than what we do to them.
That is very true…Being Kynar pumps they say that you don’t even need to rinse them, we do daily though.
Good to know. Thank you for the info!
Jesse
Atlas Services
North Carolina
Mroberts are you using a ball valve or did you find a 3/4 trigger gun? I can’t seem to find anything but 1/2" trigger guns.
Jesse
Atlas Services
North Carolina
I use a ball valve. I had the same problem…Glad to help…
Cool. Thank you for the info. How do you like using the ball valve as opposed to a trigger gun?
Jesse
Atlas Services
North Carolina
it takes some getting use to it, but once you figure it out you will love it. You can control the flow from the ball valve while on the roof
We use a 1/2 inch pvc ball valve and an 18inch pvc riser on our fatboy setup. Haven’t used guns in a few years.
Good to know. Thank you Jason!
Jesse
Atlas Services
North Carolina
