First Trailer Build Help
Hey guys,
I’m pretty new to pressure washing but not new to exterior cleaning. I’ve been doing window cleaning in SoCal and built my own RO/DI waterfed system, but now I have a client with a 3-story beach house that wants the driveway pressure washed and the house soft washed before she sells it. And just want to get into the Business ASAP!
I’m trying to build a simple, reliable setup on a 5x8 Tractor Supply trailer, and I want to make sure I’m not doing anything dumb before I start buying everything.
Machine I’m planning on:
– Predator 4400 PSI / 4.2 GPM gas unit from Harbor Freight
Surfaces I’ll be doing:
– Mostly stucco / hard textured walls (SoCal style, not vinyl)
– Driveways, walkways
– Some tall / narrow 3-story beach houses and regular 2-story houses
Tank / water setup idea:
– Trailer: 5x8
– Tank: I’m torn between a 100–150 gal vertical tank or a cheap 275 gal IBC tote
– I’m in SoCal so most houses have city water. I was thinking:
– 100 ft garden hose from spigot → buffer tank (with float valve)
– Bulkhead low on the tank → filter/strainer → 1" or 3/4" line to the Predator
I know 275 gal of water is heavy, so I’m not sure if that’s overkill for a 4.2 GPM machine doing mainly residential. Would you guys go 100–150 gal instead of a full tote on a 5x8?
Pressure side / hose lengths:
– 16" surface cleaner (something like a Wojet that works well with 4+ GPM)
– 150–200 ft of 3/8" pressure hose (rated 4500–6000 PSI)
– Basic gun + wand + J-rod
Chemical application – downstream vs soft wash:
This is where I’m the most confused.
Option 1 – Downstreaming only
– High-draw injector sized for 4–5 GPM
– 5–10 gal chem jug with house wash mix (SH + surfactant)
– J-rod (soap and rinse nozzles including a shooter to reach 2–3 stories)
Option 2 – Build downstream now, add a 12V soft wash later
– Start with downstream to keep the budget reasonable
– Later add a 12V soft wash pump (5.5–7 GPM), 150–200 ft of 1/2" chem hose, and a 50–55 gal mix tank for stronger roof/house wash mixes
My main questions for you guys:
  1. For a 4.2 GPM Predator, what buffer tank size would you run on a 5x8 trailer for mostly residential? Is 100–150 gal plenty, or would you still go 200+?
  2. Is downstreaming enough for regular stucco houses and light organic growth in a beach town, or would you say a 12V soft wash system is basically mandatory for 2–3 story stucco?
  3. Any must-have fittings/plumbing tips for the tank → pump setup so I don’t starve the pump or cook it? (bulkhead size, strainer type, return line from unloader, etc.)
  4. For hose lengths, does 150–200 ft of pressure hose and 100 ft of fill hose sound right for normal residential, or should I bump anything up?
I’m trying to build this smart the first time so I can start offering house washing and driveway cleaning along with my window cleaning business. Any advice, photos of similar rigs, or “don’t do this, ask me how I know” stories would be super appreciated.
Know that most direct drive pumps (side mounted onto the pressure washer engine) aren’t known for pulling water. They typically rely on the pressure of the water coming out of the spigot to feed the pump. There are guys who have had luck using a buffer tank when figured correctly, but, if you are washing houses that have consistent, clean water coming out at 5 or more gallons a minute then the buffer tank isn’t a necessity.
Downstream injector - opt for the smaller (lower gallon per minute) one. It’ll pull a stronger mix which you will need.
Downstreaming may not be the best option for you, depending on the level of cleaning solution you are trying to put on the side of the house. Most DS injectors don’t draw at a high enough rate to tackle gnarly stuff often embedded in stucco surfaces. But, if it’s just dust, dirt, pollen, etc, then that shouldn’t be a problem. But often times the mildew is deep in the little divots of that surface and you want a stronger mix to provide that effective cleaning ratio. It just depends on what’s on the surface of your homes. I’m not familiar with the SoCal area so I can only provide insight from my own experiences here in muggy and humid South Carolina.
Just a comment on your buffer tank question. If most properties in your area are on city water, you likely have decent water pressure. A 4.2 gpm machine is likely putting out a bit less than that at the nozzle (after the pump pushes water through your pressure hose), and so it may well be that you need a vastly smaller buffer tank than you think. A real-world test would be the best thing to try, but based upon what you’ve said I think you might even get by with a vertically-oriented 50-gal buffer tank (or drum). Vertical so it builds the most water pressure for that direct-drive pump which probably doesn’t suck very hard.
You need to have the tank outlet higher than the pump inlet. That way it can gravity feed to the pump and bypass from the pump to the tank so you do not over heat your pump when off the trigger. Sorry looked your pressure pump up it do not have a easy way to bypass back to the tank.
I wouldn’t run a buffer tank with a 4 GPM unit. Sure they can be gravity fed, kinda… but always end up being more finicky and a hassle then just running a belt or gearbox.
Keep in mind that water weighs about 8 lbs per gallon. A 275-gallon tote would put you well over the limit of the trailer you’re looking at.
Downstreaming doesn’t do much on stucco around here. Needs to be closer to a 3% mix to get good results.
Buffer tanks gets a float valve, mesh filter, shut off valve, and cam locks… that all depends on the machine you end up buying and what size mesh, feed hose, etc you can use. If you really want to get fancy, you can install a water-level shutoff valve that kills the engine if the buffer tank runs low. But again, that’s overkill for a 4 GPM machine.
I run at least 200 feet of water hose and pressure hose, and even then I sometimes have to get creative with parking and placement. That said, homes here are more spread out than they are in California.
My unsolicited advice: build a 12-volt system that you can easily take in and out of your truck. Let every window cleaning customer know you’re also offering house washing. If they ask about concrete or sidewalks, rent a unit from Home Depot for those jobs.
Once you’ve made enough money (or have enough consistent demand to justify offering these services full-time) then invest in quality name-brand equipment.
Keep it as simple as possible and you will be happy!
Ditch the Predator and get you a honda 4-5.5gpm (3000psi minimun) belt or gear drive machine, 100 gal should be plenty and depending on average flow out there, 50 may be enough. You don’t have the heavy mildew out there like we do in the south, so even with stucco you can probably DS it. I know most the drives out there are smaller, but the more flow you have the easier it is and that’s also true with rinsing stucco, especially if it’s 30-40’ up.
Yeah I had a 100 Gallon tank mounted high than my predator with a 1” hose hose running to the machine (getting 10GPM during my test) and it still didn’t work because there wasn’t enough PSI pushing into the machines inlet..you’d have to buy a marine battery & a transfer pump to make it work..at that point, a Honda would just make more sense
Them small bore/stroke direct drive pumps aren’t too good at fighting gravity
It seems that you have a well-thought-out initial rig plan. As your workload increases, you can always add a 12V soft wash system later. I would stick with a 100–150 gal buffer tank on a 5x8 trailer and start downstreaming.
