So far i have tried bear semi transparent it sprays ok. Valspar was about the same. Cabot gold sunlit walnut… THE WORST… It will not spray and the only way to do it is with brushes and rollers it will also leave drip marks very bad ones(wiping it off doesn’t help much) I literally broke even on this job. I worked 8+ straight hours for no money . It turn out amazing though ill take pics tuesday when i pick up the check and remove tape.
Im thinking of trying readyseal next time if it goes on good spraying and minimal brushing ill refuse any job that doesn’t want me to use it and only use it from now on.
It claims to spray evenly and not leave lap marks or drip marks.
I see people swear by grey away for wood. I’m watching this thread closely. I plan on adding this if I hire more or slow down. I have a lot of fence to practice on. Keep me posted on what works. Thanks
Problem with the bakers is that no one carries around here. It’s made in TX and they don’t have very good distribution. The Ready Seal is pretty much about the only thing I’ll do a job with. The Behr isn’t bad, but most the time you need to back brush or roll.
I have the same system. He is actually the one who talked me into it. Expensive, but it makes quick work out of fences. Most decks I still do by brush, hand mit on the spindles.
