Hey All,
Thanks to all you BA wood guys and all your discussions, I cleaned & brightened a fence using F10 Sodium Percarbonate & Oxalic Acid. I followed the typical process and it turned out great. Here’s what I did…
- Pre-Wet Wood
- Applied F10 ( 8oz of F10 / 1 Gal Hot Water) using 3 Gal Pump Sprayer
- Let Dwell for 10 min but Agitated it with Stiff Brush at 5 min
- Rinse with Water using 4009 & 4008 Tips (4GPM / 4000 PSI - 250 ft Hose)
- While wet, Applied Oxalic (12 oz Ox / 1 Gal Hot Water) 3 Gal Pump Sprayer
- Immediate Rinse with lots of water.
The pump sprayer took time. I need to build a 12V pump cart.
Results were good, customer was happy! Thanks everyone! Hope this helps someone too.
Pic Color Corrected:
Upper - Left Half Pre-Wet / Right Half Not
Middle - Cleaned with F10
Bottom - Brightened with Oxalic
