Would like to see if I can sell this whole unit before I part it out.
As of right now (more may be added), this is what is included:
2004 Isuzu NPR with diesel engine. 171,8XX miles. Runs great. Could use some front tires. Truck has 14,500 lbs load capacity. Chemical resistant fiberglass box built by supreme. Originally a Trugreen truck, so built for hauling liquid chemicals and servicing residential accounts. The truck is painted green and has vinyl graphics that can be easily removed.
Pressure pro 8 GPM cold water 3000PSI machine with 407 hours on it. Runs fine, never lets me down.
Electric hose reels (brand unknown). These work but could use some TLC. They need new drive chains and the top reel is warped. They work, they’ve just seen better days.
Ladders: 12’, 21’ and 40’. The 40’ ladder is a year old and has only been used about 5 times.
Tanks: 300g tote, 50 gallon leg tank and 15 gallon soap tank.
Hose: 200’ 3/8 blue goodyear pressure hose and 300’ Blue Kuri Tek ag hose.
Mounted 5850 chemical pump.
Various pump ups, lances, brushes, extendable poles, spray bottles and squeegees.
Many chemicals such as open 5 gallon buckets of F13, Elemonator etc. and powdered chems such as Sodium Hydroxide and Oxalic acid.
Whisper wash ground force surface cleaner.
There are many other odds and ends for washing like quick connects, jrods, o-rings, plumbing pieces, etc…
Again, I would like to try to sell as a package before parting out.
I am willing to drive the truck to you as long as you add in the cost of a plane ticket back to Buffalo, NY.
The price I am thinking is $9,500 for everything. I can be reached at 716-868-6658. Buffalo/Niagara Int.(BUF) is the closest airport (20 mins away).
